SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
SOURCE: I have the EXP 2000 NordicTrack incline treadmill
Manuals can be downloaded at http://www.iconservice.com/CustomerService/manuals
First perform an incline calibration.
Insert the safety key/magnet. Press the incline up button. While the numbers are changing, remove the key. Release the incline up button and reinsert the key/magnet. The machine should go to the top and then back to the bottom.
If it only starts then stops, the incline sensor may be defective. Be sure all the plugs are secure on the controller board.
If the sensor is defective, you will need to order a new incline motor..
If the incline motor does not move at all, the controller may be defective..
SOURCE: nordictrack c2050 treadmill is stuck
Watch this videos+ tip:
http://www.youtube.com/watch?v=bF3OyQ3HwfU
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=Uzf4az4RRDE
http://www.youtube.com/watch?v=MIIxoPtvhy8
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
sincerely. Please keep me in touch.
