SOURCE: unable to display password sreen
Hi Try this: Control Panel =>User Accounts =>Change the way users log on or off =>and uncheck the select box "use the Welcome screen. If you need help ask. Good Luck.
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
SOURCE: SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly
installed
For the 'CH' check the covers and make
sure all covers are closed properly.
For the 'Blinking CH' take the dev.
Unit open and the reinstall unit properly.
Pls rate – thank you
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
