Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
SOURCE: Why when i turn on my TCL smart tv i am seeing this on my screen and it not loading
Hi, Check the connections on the back and that they are secure and tight. If problem persists seek out repair. Looks like T-con board(s).
Can be expensive to replace. You might find buying a new TV a better way to go. Good luck.
Possibly fuel filter.. very common problem.
If is not a bad idea to replace it as a maintenance item anyway. They only cost a couple bucks. While the car is running, have someone mist some spray start or even gasoline(using a spray pump bottle) to see if you can keep the car going longer than 10 seconds. If the car keeps running while you are misting fuel in, then you know it is a fuel flow issue. Determine where the air filter is, you need to open the air filter housing, remove the air filter and that is your air intake. This is where you need to mist in spray start or gas. Check the air filter while you are at it. Could be the fuel pump too. Some vehicles have a fuel pump reset/breaker button that may have been tripped. Google it for your vehicle, may or may not have one.
