SOURCE: Rainbow E Series Suction Problem
Being an E series some have a corrgated filter in the top, there is also a filter on the back. Could be a motor problem, not turning as fast as it should, in which case you will have to replace the motor. You might check, some had a 10 year warranty on the motor. If you are the original owner and only have had it 5 years, then it may be covered.
SOURCE: Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
SOURCE: Vacuum was used to clean up after plaster sanding.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=645474
Generic problem for all Vacuums
Posted by veronica1113 on Jun 04, 2008
Could the debris from plaster sanding cause my rainbow series D4C vacuum not to work? If so how is the best way to clean it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow D4C will still work but not @ the highest efficiency rating – the suction will be reduced because the sheetrock dust gets into the motor and the fan blade(s) Quan 3 and would need a professional cleaning 1st or 2nd. Replacement of the motor; if it is too serious and or too expensive. It’s a good vacuum back it is suggested that people use a good Shop Vac for the sheetrock dust removal. Feel free to contact your local vacuum cleaner dealer in your area or you can try to repair and change out the fans, clean out the carbon brush area and cleanup the armature. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: RE: Installing rainbow E series water pan latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=652000
Posted by bettyannsoto on Jun 06, 2008
Need to know how to install rainbow water pan latch and spring latch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow latch can be replaced but I believe it is a pop rivet that holds and replaces the old latch and to replace the new latch, I have seen it done but if you don’t have the right tools you may want to contact your local vacuum cleaner dealer in your area, it can be done. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
SOURCE: rainbow stops shortly after starting to vacuum
There is a thermal fuse on the motor field that sometimes fails. Sometimes the fuse does what it is supposed to do - prevents motor from overheating.
Causes:
a) Improperly worn motor brushes
b) bad motor bearings (that usually leads to uneven motor brush wear)
c) very dirty cooling air filter
To access filter and the motor - use small flat screwdriver to remove clear side panels. You will see 4 or 6 Phillips screws. Remove screws - cap will come off.
Good Luck,
Rocky
