Air Purifiers Logo
Jane Schaffer Posted on Mar 11, 2019
The light in my Lux Guardian Air purifier (Aerus) is blinking? What does this mean?
Cate Melvin
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 31, 2019
Cate Melvin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1344
Points
6
All you need is to replace the UV light. Call your local Aerus or Aerus Electrolux store get one delivered to you! Easy peasy.
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 13, 2008
SOURCE: Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Anonymous
  • 114 Answers
  • Posted on Aug 19, 2009
SOURCE: lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Anonymous
  • Posted on Nov 30, 2009
SOURCE: blinking blue light on ionic breeze s1871
the blue light keeps blinking
Anonymous
  • 141 Answers
  • Posted on Apr 05, 2010
SOURCE: Hi, I have the ionic breeze s1871 air purifier and
did you cleen the fins on the inside remove them and clean them verry well
Anonymous
  • 10 Answers
  • Posted on Jan 03, 2011
SOURCE: Blinking red light above the
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
I hope you post what you find out!
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
1helpful
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Reset buttton location
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself.
I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
Replace phi 212 ga cell for guardian air
You can find replacement cells for the Guardian Air RGF products here:
http://hvac-parts-online.com/indoor-air-quality-replacement-uv-bulbs-c-82263_82296
You will have to call for current pricing. The manufacturer has asked us to remove pricing from the internet. 941-735-7151
Need replacement phi cell for guardian air. zip code 45365
You can obtain replacement cells for the Guardian Air RGF products here:
You will need to call us for current pricing. The manufacturer has asked us to remove pricing from the internet. 941-735-7151
5answers
Need your help
Wireing Schematics for power supply board of Kenmore C347-32953 air purifier. Not sure if connection P4N is ground (black wire) or does it go on connection P1L beside it.
Top Air Purifiers Experts
NOEL
NOEL
jws1013
john h
Are you an Air Purifier Expert? Answer questions, earn points and help others
