Question about Precor Exercise & Fitness
My precor 921 treadmill drags at certain points.Is there a fix for this?
    Top Expert:
  • 1,116 Answers
SOURCE:
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
SOURCE: c956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Posted on Feb 12, 2010
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
seanmccann_1
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Posted on Sep 07, 2012
ercupa190
  • 12223 Answers
SOURCE: err 40 mess comes up on a precor 921 treadmil and shuts down. will restart but shutdown
see this steps and procedure and fix it. God bless you
Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Posted on Oct 09, 2012
My PRECOR TRM 800 wiht the P80 console will not work with Quick Start.
If rebooting the treadmill does not fix that, it may have a problem with the Autostop feature. The MCB may need to be replaced to fix that problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
May 27, 2014 | Precor C956i Treadmills with HR /...
Precor 956i
Sometimes a bad MCB will cause a vibration at certain low speeds. If you have another unit, swap MCBs to verify.
Feb 07, 2014 | Precor C956i Treadmills with HR /...
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
When walking on treadmill it stick like it want to stop
This sounds like either 1 or 2 things. Either the belt is worn to the point it needs to be replaced or the belt and deck need to be lubed. The video below will help you by showing you how to apply the lube and link below will give you an option to purchase the new belt and deck. Please use your model and serial number to narrow down your choices.
Precor Repair Parts for 942 944 Treadmills SPORTSMITH net
Dec 11, 2013 | Precor Treadmill Belt 940, 942, 944...
How do I fix an ERR70 message on the display of my 9.21 treadmill.
Precor Error 70, LPCA Not Read Probable Cause Incorrect or missing software in the LPCA
Corrective Action Test with a known good LPCA Precor Error 70 LPCA Not Read AMT12 Only
Jan 05, 2013 | Precor 9.21 Treadmill
Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
Jul 06, 2012 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Upon powering up my precor treadmill goes straight to the highest incline
hi,
Your treadmills motor controlling circuit have some problem. thats why you cant adjust its speed. its running at its high speed because its motor controlling IGBT become shorted. As these potion of your treadmill is a high voltage point, i will recommend you to consult the manufacturer for support.
ok
Jun 07, 2011 | Life Fitness Treadmill Precor C954 (Used)
After walking for 10 minutes or so, or even sooner when I am jogging, the 921 loses power and trip my house circuit breaker. What needs to be replaced? Guessing it is the power cord as the 921 is 20...
Check your Amps on the circuit that is being tripped. The treadmill needs 15 Amps to run. If you have a 15 Amp circuit that is running the treadmill and other electronics (or lights), the circuit will trip. You may need to replace the circuit with more Amps.
Mar 02, 2011 | Precor 9.21 Treadmill
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Exercise & Fitness Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
