COMPRESSOR
If you are in the USA
A compressor must be replaced by a certified refrigeration technician due to federal laws about proper handling of refrigerant. Also, all the joints must be soldered together with a torch, this is not a job for an amature.
If the fridge is less than 5 yrs old it should still be covered by the sealed system warranty and repaired at no charge.
I do know that the compressors for many of the SxS fridgidaires have been on back order due to a change to a different brand of replacement compressor. I recently waited 2 1/2 weeks on one I had ordered for a customer.
Once the tech has the compressor it is usually about a 2 hr job to replace, depending on the model.
Most of the parts dealers you contact will be hesitant to sell a compressor to someone that is not in the repair buisness, due to warranty claims if it is not installed properly. If you want to get one yourself you should be able to order it through Sears if you can't find it anywhere else. Go to sears.com, click on parts and enter the complete model number from the sticker in the refrigerator. If your model isn't listed you can call the 800 number on their site.
Hope this helps.
