Televison & Video Logo
Mark Funk Posted on Mar 11, 2019
LG 47 inch tv turns on Leds flash and go out. What's wrong?
Model LG 47LN5400 UA. I am wondering if it is a powerboard issue or LED strips?
karen sharon
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 28 Answers
  • Posted on Mar 21, 2019
karen sharon
Contributor
Level 1:
New Friend:
Night Owl:
Answers
28
Questions
Helped
4077
Points
66
Check voltage on tv psu output
3 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Oct 27, 2016
SOURCE: have a LG 47 inch tv. 47ln5750. When I power on the LG appears on screen then shuts off. took off the back cover and when I powered on I could see the LEDs flash. problem be led board? Or Led strips?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
gopakumarg43
  • 76851 Answers
  • Posted on Jan 27, 2017
SOURCE: I have a 47 inch lg flat screen 47ln5400 is the model number, I power it on and you can see the tv with a bright light and it still produces sound what parts would I need to fix it?
T'Con board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name of your device in the search box at the top of the display window to get gathered all the related posts.
russ_hill007
Russ Hill
  • 4057 Answers
  • Posted on Apr 22, 2018
SOURCE: I have an LG 42LP620H-UH led tv, will led strips from another LG model 42 inch led tv work in mine?
as long as they from the same screen number as the fittings can be a different shape. some are 2 line some are 4 line but only work on 2 or 3 as dim and bright controlled by the picture inputs.
We have an LG tv that has sound but no picture. I thought it needed a backlight inverter but parts co. said the model was LED & doesn't have an inverter. So what's wrong.
most likely the problem is if your lg tv is between 40 and 50 inches that the internal LEDS have gone bad typical with LG models you need to replace the LED light strips inside the panel and it is not easy to do unless your experienced with this take it to a shop or see the link below for more info LG 39 LED TV Model 39LN No Backlights Bad LEDs How To Replace LED Strips
1helpful
2answers
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
LG 47LN5400-UA LED picture has gone out. Audio works. Using flashlight I can see faint menu image. LED Driver or LED Strips? How can I tell?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
LG 47LN5400 blank screen after brief flash
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
3answers
LED tv LG 50LN5200 with no picture but has sound
Faulty the backlight
It is necessary to remove the panel and replace defective LEDs
Best Regards!
Have a LG 47 inch tv. 47ln5750. When I power on the LG appears on screen then shuts off. took off the back cover and when I powered on I could see the LEDs flash. problem be led board? Or Led strips?
How do i remove the screen from my lg 47" tv to replace the leds?
If you wish to get some details; check the site linked here. Pull up older posts.
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
My LG 47LN5400-UA flatscreen has a black screen, everything works fine except black screen, when I shine flashlight on screen I can see full color picture, I have replaced the power supply/LED board.
Can you tell if LED tv has bad LED strips before changing LED Board/Power Supply (as they're in one piece on a lot of TVs)?
This is not easy to diagnose, either use a meter on the power cable to the led or check the leds one at a time
1helpful
Which part needs replacing on the TV? See details.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
