Question about NorStar Lands Phones
I have a Norstar 7310 and somehow all of the buttons act as the RLS button. you can pick up the headset and get the dial tone, but when you go to dial a number or Intercom button it will end the call
SOURCE:
  • 3 Answers
SOURCE: My intercom button flashed red to green.
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Posted on Jul 26, 2008
SOURCE: can't dial out
On my 9417cw this happened from time to time and I found a very simple solution. Disconnect the power supply for a few seconds and plug it back in....voila!
Posted on Nov 14, 2008
cnavarro
  • 2460 Answers
SOURCE: PLEASE, PLEASE try and help
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
Posted on Nov 25, 2008
Vit Avaya BP
  • 211 Answers
SOURCE: System Program & Central Tel Program buttons don't work
This is not a common problem.
Take that phone to a processor and plug it into extension. If no longer seing a problem look into wiring. If problem still there, try a different phone. If different phone works fine you have a bad phone. If problem still shows you have a bad port on a processor. Try available different port. You should really contact your Avaya vendor to fix this.
Posted on Apr 07, 2009
  • 60 Answers
SOURCE: Norstar M7310- buttons don't produce tone anymore
Have you tried un plugging then plugging them back in to reset them, if not you may have to power cycle the main system.
Posted on Jul 28, 2009
How to program feature buttons on meridian 7310?
Go to 7310 set you wish yo program leave handset on hook push feature star 3 then the button you wish to program then feature and
the code you want ex:feature 0 is speed dial that key will now be
programmed for speed dial. You cant program line keys or intercom keys.
Sep 02, 2014 | NorStar Meridian M7310 Phone
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
We have a meridian M7310 telephone system, and have just bought some headsets. Unfortunately we wish to use both headset, handset or speaker phone. Is this possible? Because at the moment we can only...
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
May 13, 2011 | NorStar Meridian M7310 Phone
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
Sep 23, 2009 | NorStar Meridian M7310 Phone
I have a Norstar M273724, and I am having one HECK of a time trying to program my personal speed dials. Any ideas?
You need to use Feature *1, Then press the button you want to program, dial the number, and press Rls or Release
Jun 11, 2009 | NorStar M7324 Phone
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Oct 24, 2008 | Plantronics CS70 Wireless Headset
Lands Phones Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
