Refrigerators Logo
t
thabo Posted on Mar 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for the software for sc-750u magnetic strip
Chris Walker
Level 3:
Top Expert:
  • Refrigerators Master 1,573 Answers
  • Posted on Mar 11, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244359
Points
21965
I have a whirlpool tub, with a side panel that allows access to the mechanics, and the panel is just held on with cheap velcro. We put commercial grade velcro on, as the panel kept falling off, but it too...
If Velcro is not working for you try some magnetic strips. Purchase some magnetic strips attach to both the cover and the tub. Be sure the polarity of the magnetic strips is correct so they attract each other. You could glue the strips to the cover attach the tub strips to the cover strips then apply glue to the tub strips and apply the cover to the tub allow the glue to dry and that would insure correct polarity and positioning of the strips. Hope this helps.
Bob
Aug 22, 2014 • Home
How to stop beeping when on battery
Just depends if there is a display to enter into the menu and disable it. or by installing the software on to your laptop. But the software might be just for looking at metering such as voltages, currents, turning the UPS ON or OFF, etc. They usually allow you do disable the beep. But some don't allow you to do anything as to change settings. If you had a bigger ups with display, it will allow you. 3000va's and up, i believe.
How to you replace the freezer door seal
is it a latched door, if so weather stripping (high density foam) is a good alternative, commonly used on edges of doors, believe it or not that is a door seal just without the cover to make it more pleasing to look at, it comes in various depths, sizes and is normally two sides adhesive. if it is a magnet strip type; pick a side and use it as a strip magnet surface or cover it.
11helpful
Where can i download mini 123 sc program?
try searching mini123sc on hotfiles.com but the software is a pay for software package and these dowloads will be illegal but the choice is yours.
5helpful
2answers
Need drivers for magtek 21040102 to run it on windows 7
The best tool for keeping your drivers up to date is: driverupdate us Its, easy to navigate (user friendly) and easy to install. take a look
2answers
Cannot use our magnetic stripe cards to login. They scan ok but do no work.
Wrap the magnetic strip in a plastic bag (the kind of plastic bag you get at a grocery store) and then swipe the card and it will work just fine. I learned this working in gas stations when the customers card did not work it would work when the strip was wrapped in plastic
I had my UPS from Tripplite at least 4 years or more. It's a Tripp Lite Internet 750U UPS. It does noe beep anymore or and when you press the on and off botton the light does not come on. Does the battery...
Battery is very easy to remove. Take it out and test it. If you dont have a meter to test it take it to an interstate battery store they will test it for you. They sell new ones should you need to purchace one.
2answers
Help
por favor necesito software de la camara sc 3300 es urgente
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
