Just got my ticket, how do I attach a scope to the radio to monitor what it is doing?
SOURCE: OLDER ICOM RADIO ICBP5 AND A REGENCY U156B
Hi, The Icom radio models start with IC followed by numbers and then letter(s). The BP5 is the model of the battery pack. Pls post back. I'm not familiar with Regency U156B. However, there is a Regency RU156 which is a 16 channel UHF 25watt mobile radio which could either be crystal controlled or PLL diode matrix. Regency was reported sold to the BK Relm Company, which no longer supports older Regency Radio Equipment. There are a few sites on the Internet where you can get hold of a user's manual (some for a fee) like http://www.bearcat1.com/manuals.htm. Hope this be of some help/idea. Post back how thin gs turned up, the Icom model or should you need additional information. Good luck and kind regards.
SOURCE: Bendix King 5102 DPH 138-174 Ham band won't RX
wb6sub, hi don't know if you have the manual for this radio or not, but if not, here is the link for it;
http://www.49ercom.com/pdfs/DPH_Program_manual.pdf
On page 15 it mentions contacting BK for the software to go with your cable.
"2.4 PROGRAMMING BY COMPUTER
Programming a radio from a computer is not covered in this manual. Contact BK Radio for the programming cable, software, and manual required".
http://bkradios.com/thumbnail.asp?offset=0&deep=2&cat_id=202
Hope this helps you out in your search, let us know,,, Mechanic
SOURCE: YAESU HAM RADIO FT270R DIAGRAM
http://www.radioamateur.eu/schemi/FT270_sch.pdf
google is your friend
SOURCE: Trying to convert marine radio to ham band ? Cybernet CTX 1200
big shuift 156 MHz to 144 MHz !!
SOURCE: service manual for icom 706
It's available in adobe reader format from http://www.repeater-builder.com/icom/pdfs/icom-ic-706mk2g-service-manual.pdf
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats the case you will need an Icom that will do UHF freqs.
