SOURCE: program
Try to see if it flashes an error code, that could help identify the problem. Otherwise, if the problem is only with programming and not with the actual dishwasher, you might want to try replacing the program timer module.
SOURCE: Selecting speed dial number
Select the numbers from the directory, using the directory button.
SOURCE: Selection dial has come loose.
Found I could unthread the knob (counterclockwise), then removed the selection plate, and its adapter. Noticed that it was originally welded to the plate, via 3 palstic studs. I was able to determine that the two plates would ONLY align in one postion, and then was able to ReGlue them together, courtesy of No More Nails. All is well in Washerville again.
SOURCE: When switched on the pumpbutton stays red and the
Thanks to a manual that was sent to me I understould I had to press the button P for a long time, that resets the machine. Thanks for your service! Carolijn
SOURCE: Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
