SOURCE: Porter Cable 18 ga Brad nailer - BN200 Will not reload
Strip and clean the whole diaphragm and spring arrangement. Also check whether a bad nail hasn't damaged the piston guide and caused it to jam when on return stroke.
SOURCE: Porter Cable 2 inch brad nailer piston does not return
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
SOURCE: BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Where might I find them?
