SOURCE: My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
SOURCE: manual for a 3ve51 dayton heater
Check under construction heaters online www.desatech.com. They should have what you are looking for. Thank you
SOURCE: Dayton 3VE51 oil fired heater
Hi check for blockage in the flue check out the pressure switch, check heat exchanger
SOURCE: I have a 75k BTU Dayton hanging gas heater that
This problem is caused by a bad flame sensor (looks like a spark plug) which can be cleaned by sanding or with steel wool.
