Question about Janome Sewing Machines
I don't know what could be wrong with my janome 8000 sewing machine when I turn it on it don't here the motor which make the norm sounds when it load up and the tension light don't come on but you can see the screen light come and and off
    Top Expert:
  • Janome Master
  • 61,734 Answers
SADLY NEITHER DO I TAKE IT IN FOR SERVICE
Posted on Mar 11, 2019
SOURCE:
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
Posted on Jul 11, 2008
  • 323 Answers
SOURCE: janome memory craft 8000
The screen is going bad and needs to be replaced. Unfortunately, it is obsolete.It is my understanding that a Janome Dealer can take your screen and send it to Janome to be rebuilt. It will take about a month. Be prepared to spend more than $200. The sewing light is the same one that is used in many Janome machines I.e. MC9000 and should be available from almost any competent sewing repair shop.
sewman7
Posted on Oct 28, 2008
  • 323 Answers
SOURCE: JANOME MEMORY CRAFT 8000 - TENSION
You need to do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
If it still messes up ,remove the bobbin case and examine it for burrs or scratches. Remove them with and emery stick and fine steel wool.
sewman7
Posted on Nov 04, 2008
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
  • 161 Answers
SOURCE: My Janome memory craft 8000
step motor error may mean the embroidery arm is out of position gently push it back home towards the machine and see if this helps. If the mother board is gone, they will not be able to replace it as its so old, but you may be able to get an 8000 or 9000 on ebayso you can still use your discs if you don't want to get a new machine
Posted on Sep 11, 2010
My Janome 8000 is toggleing between manual and embrodery and won't stop. Dealer doesn't know what is wrong with it. Any suggestions?
The dealer doesn't know??? I would expect the dealer to find out or at least give you options for sending the machine to a Janome repair shop.
Feb 04, 2018 | Janome Sewing Machines
My Janome memory craft 8000 will only sew backwards and the screen shows step motor error. the machine is 19 years old. Is this fixable?
Aug 09, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
How do i install my el board in my janome mc 8000 sewing machine
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light Janome Memory Craft 8000 LCD Backlight Replacement Kit. The kit comes with a custom repair manual specifically written for back light replacement.
Dec 28, 2009 | Janome Memory Craft 9000 Computerized...
Janome 8000 LCD question
Hi Lezlie,
I shall send you the installation instruction to gain access and replace the screen via email.
Cheers
Martyn
Dec 22, 2009 | Janome Memory Craft 9000 Computerized...
JANOME MEMORYCRAFT 8000 STEPPING MOTOR ERROR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 8000 Stepping Motor Error
Bear with me here...
When the Janome 8000 is turned on, one of the first things that it does is run the stepper motors to return the embroidery carriage back to its original position.
The computer in the Janome needs to know when the embroidery carriage is back in the correct position and to do so, it uses a sensor.
If the sensor fails, it does not know that the carriage is back in the correct position.
When the sensor fails, what happens is that the stepper motor keeps running even though the embroidery carriage is fully back, so what you hear is a horrible grinding sound. The grinding sound itself is nothing to worry about, actually it is good news, it means that the stepper motor is fine.
Janome in their infinite wisdom decided that whether the motor failed or the sensor failed, that they would simply say on the screen that the stepper motor failed.
I have repaired a machine with this problem, in my case it turned out that the sensor was okay, but someone had damaged the main circuit board, breaking the track from the sensor to the computer.
Unfortunately, I don't know if this sort of repair is something that the average repairman can take care of. I am an electronics engineer, so thats why it wasn't a problem for me.
I just thought some extra information on what is going on might give you a head start in getting some one to fix it for you.
Oct 01, 2007 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
