Thank you i found out it was because of corrosiin on the bottom front part of that screen so its broke.Thank you i found out it was because of corrosiin on the bottom front part of that screen so its broke.
You can't post conmments that contain an email address.
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
yes, you can but you need the right tools and follow the instructions, but you better think the cost to repair because,you'll need parts , tools. shipping expenses ,time to expend and guidance to do the job,just the tools and the parts you may need can cost to ,you no less than 100.00 if you want to try let me know
it could be a screen cable fault. there is not much info on this model but would believe it would be the 2 cables on the lcd. if its the old tube type tv, when its been transported something could of come loose inside cable or a soldered part, to you would have a dry joint hope this helps
Have the same problem myself (although I'm not sure what the cause is). You'll probably have to change the screens (I'm currently still experimenting if I can clean up or reset the connectors to the screen).
