SOURCE: Wolfgang Puck Bistro 5 qt Pressure Cooker. How to steam?
I cannot find the instructions how to set up and use this new machine..can you send over and I can print?
SOURCE: I NEED TO REPLACE THE PRESSUR RELEASE VALVE.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
SOURCE: I HAVE A WOLFGANG PUCK
Not sure if your model is the BPCR0175 but gaskets are available on-line for the models shown; you may want to confirm compatibilty with their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
SOURCE: Looking for a replacement crock for a Wolfgang
Replacement parts for Wolfgang Puck Crock Pots are available here:
http://www.wpcookware.com/categories.asp?cat=31
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
SOURCE: displays E2 and E4 (5 qt Wolfgang Puck pressure
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
