s
sybil gold Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
530 r00mba has dock lightstuck, how do I unstick? I take it off charging station, but as soon as I push clean, it goes back to dock.
roeb
Level 3:
  • Master 819 Answers
  • Posted on Mar 10, 2019
roeb
Master
Level 3:
Answers
819
Questions
0
Helped
384839
Points
2343
Batteries are weak or wiring to battery or controller either corroded or loose.
5 Related Answers
Anonymous
  • Posted on Apr 26, 2008
SOURCE: audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
bobfiala
bobfiala
  • 28 Answers
  • Posted on Nov 14, 2008
SOURCE: Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Anonymous
  • 71 Answers
  • Posted on Jun 01, 2009
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
Anonymous
  • Posted on Jul 08, 2009
SOURCE: ipod nano not charging on jbl docking station 2
my apple ipod is not charging what should i do plz help me [nano 3rd genaration]
Anonymous
  • Posted on Oct 16, 2009
SOURCE: new ipod won't charge on bose docking station
I have been looking for sometime and have finally found a 3rd party power converter. Another solution is to send your docking station to Bose and for $99.00 they will repin the dock so charging will work. The converter and adapter only cost about $30.00. Here is the link to the site I ordered from. I just ordered it so I am not abot to confirm functionality yet.....
http://www.griffintechnology.com/products/firewire-to-usb-converter
I have roomba 880 stationed in open w/nothing blocking view (virtual walls, lighthouse, doors, etc) but it will not go back to docking station even when I press docking and its only 6 feet away.
it seems as if the robotic cleaner is having a problem sensing where it is or failing to notice where its charging station is try cleaning any optical/IR sensors and it maybe able to see once again where its charging dock is
Why is there no green light or red docking showing it is charging?
Sometimes the contacts between the battery and the iRobot get corroded...you can try using a small piece of sandpaper to lightly scuff/clean the battery contacts. Once you put it back together, try the reset function mentioned previously.
Ipod nano rebooting on the docking station
Hello, The problem is that some of the pins onteh docking connector are shorting to others. Shorting the supply on you ipod. Don't do it!
Diagnostic videos and spares for the Bose SoundDock. There are several builds of the Bose SoundDock Original that look identical from the outside. If you visit invebo.com and enter your dock serial number you get access to the resources that tell you which version the dock's internal hardware you have in your dock, diagnostic and self repair videos and what kits you should buy to fix or upgrade to charge or Bluetooth wireless streaming. All spares are supplied on a no-risk 'buy and try' basis.
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
7helpful
4answers
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
2helpful
Docking station charges two of the three bars to green and then afterwards goes into blinking red bars and the third green bar never gets charged.
went to best buy and bought a new battery charger. i don't know what's wrong with the docking station but at least i'm back in business insofar as being able to continue using the camera.
7helpful
5answers
Docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
2answers
Can't download pics
hi
sir, u replace ur USB conecting cable
 Grubhead
Grubhead
SmartAviator
SmartAviator
