Washing Machines Logo
g
gary Fonseca Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vrt samsung washer has a 4E error code - Samsung Washing Machines
Ann Masterson
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Mar 11, 2019
Ann Masterson
Expert
Level 2:
New Friend:
Answers
152
Questions
Helped
46841
Points
227
Check your water supply if that ok check the little filter at back of machine that takes in water can be dirty if all these are ok then u May have to replace your water inlet valve
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 18, 2008
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Anonymous
  • 3 Answers
  • Posted on Jul 11, 2008
SOURCE: Samsung Washing machine fault
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: Samsung B1245 front loader
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Anonymous
  • 15935 Answers
SOURCE: 4E error....samsung J845
Al Treftz
  • 4 Answers
  • Posted on Aug 20, 2012
SOURCE: Samsung VRT Steam FabriC Softener not dispensing
My fabric softener intermiitently was left with clear water in the tray. The serviceman replaced the tray which did not fix the problem, he then replaced the valve assembly. That fixed the problem for about a year and now I am experiencing the same problem. Being the unit is now out of warranty, I purchased a valve assembly and replaced it but what I found in the process was that the real problem was that after removing the filter screen where the hose connects I found a SECOND mesh filter that was plugged up. I removed it with a needle from the edge so I didnt damage the screen. I think you could also just used a spray bottle with some water and a Q tip to clean. I wasted $50 on a valve assembly, but I did discover this second filter screen that is not mentioned in the user manual. Hope this helps someone because I have not seen this solution posted anywhere.
2answers
I have probelm in my Samsung washing machine WF-B1061
NF and 4E = No Water Feed = Washer Not Filling. This means that there is an issue that is preventing your washer from receiving water into the water inlet valve. The troubleshooting steps below apply to all types of Samsung washing machines including front load, top load, and washer and dryer combos
https://removeandreplace.com/2015/12/16/samsung-washing-machine-shows-nf-or-4e-error-code-what-does-this-fault-code-mean
I have a samsung vrt washing mashing that keep flashing a 4e code do you have any advise what look for it less than 1 year old
4E typically represents a problem with the incoming water, first step would be to check the water coming to the machine, while the water lines are off be sure to check the screens on the water valves to be sure they are not plugged.
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
2answers
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Errpr code 4e on samsun aqua jet vrt
A 4E code on Samsung washers means that the washer isn't filling properly or the sensor isn't detecting the water flow. First, make sure that the water shut-off valves are open. Next make sure that the drain hose outlet is positioned above the fill level of the washer. (This avoids the water being suctioned out of the tub.)
Turn off the shut-off valves and disconnect the fill hoses from the washer and the valves. Clean the filters in the washer and at the valves. Reconnect the hoses to the valve and place a bucket under the other end. Open the valves and check that you have good water flow from both hoses. You may want to replace the hoses. (Some washer fill hoses are designed to clamp shut if they detect a leak. This anti-burst feature will reduce the water flow to a trickle. Since the washer fill sensor detects the amount of water in the tub within 8 minutes, that will trip the error.)
If the washer isn't filling and there is plenty of water coming from the water line, the fill valve probably failed in the closed position. If the water level is rising, then the sensor is probably faulty.
Please add a comment with the full model number of your washer. Then I may be able to point you to the parts. If the washer is under warranty, contact Samsung.
I hope this helps.
Samsung VRT error code dc
dc means clog in the filter. look to the lower left front of the washer for the filter door. Take off the door and pull out the short hose. Empty the water from the hose, this could be lots of water be prepared. Then pull out the filter on the right by twisting counter clockwise and rinse the filter. Put it back together and the error should go away
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
