Hand Tools Logo
J
J.D. Ussery Posted on Mar 10, 2019
My come along (American Power Pull model# 18650) was cranked back way too much and now I can't release the cable using the free spool lever. Any suggestions?
Toolbox Widget
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 20, 2019
Toolbox Widget
Contributor
Level 1:
Answers
Questions
0
Helped
674
Points
You will get all the information on Toolbox from here https://toolboxwidget.com. Download your PDF copy today or email us to [email protected] for ordering book.
5 Related Answers
defadad
Harry Goodwin
  • 353 Answers
  • Posted on May 23, 2009
SOURCE: hood release will not release hood cable is not broken
the outer cable may have come loose near the lock, if the grille screws are accessable remove the grille and you will have access to the underside of the lock, you may need a screwdriver to push the lock lever aside to unlock the bonnet
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Jun 28, 2009
SOURCE: Hood release cable isn't connected to interior hood release lever
Your going to have to use vice grips or pliers. Just pull hard till you hear the hood pop open or have a friend push down on the hood so you can pull in the hood cable easier to unlock the hood latch. Good luck and keep me posted.
Anonymous
  • 6982 Answers
  • Posted on Sep 10, 2009
SOURCE: 2000 Chevrolet Blazer The hood release
Grab the cable stub with a pair of vise grips, have someone bounce the front of the hood while pulling...most times that will free a balky latch. Then you can change the cable.
Anonymous
  • 295 Answers
  • Posted on Nov 23, 2009
SOURCE: Stuck hood latch on 1996 chrysler concorde- Possible broken cable
take off the left front wheel and fender well. slice off the hood cable insulation get a hook too pull the wire have a buddy pull up on the hood while doing this. Should pop open then hope this helps u out.
Anonymous
  • 603 Answers
  • Posted on Jan 04, 2010
SOURCE: I have a 1989 Reliant K and my emergency break
Surprized you still have a K car running!
To fix this you'd have to get under the car and cut the cable going to the rear brakes.
I know, you don't want to do that.
It's the easiest solution.
I automatic doesn"t need a parking brake.
1helpful
What kind of batteries for the evatac flash light
My Evatac flashlight rechargeable batteries not working .when connecting batteries to charger light flashes green red green red ect. What is the problem
Jan 27, 2019 • Cameras
1helpful
My 1999 tyahoe hood latch and cable doesnt work how can iopen the hood
have someone push down on hood and try to open ---- reach behind the lever and disconnect cable use a vise grip to pull cable if cable is broken---- than behind grille is latch look through grill and will need a metal hook to grab cable and pull cable towards grille and pull through cut cable cover back and pull cable back
Hood latch won release ChevyTalk FREE Restoration and Repair Help for your... how to open hood from outside when cable breaks
How to replace the cranking pull cord?
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
1helpful
How to release an emergency brake that is stuck
You have limited choices. Your biggest concern will be the Racheting action of the Emergency brakes which takes up slack.
Check online for the Emergency Brake Assembly for your Model. There should be pictures and mention of the release mechanism. They are made to allow the cable spool to unspool, usually by moving a tab with a screwdriver tip.
Now on the wheel end, the mechanism may pull the brake levers to spread the Brakes. The pivot for the wheel lever may be frozen or the cable frozen in its travel zone.
So you have the possibility of devices taking up slack at both ends of the brake cable. Not familiar with Mazda design, if it has a hand lever for Parking brake. This style can be auto-rachet or mechanical nut and bolt style to increase or decrease cable length.
The more photos you see about the components, the better off you will be. I hope I have been helpful.
1helpful
2answers
String does not seem to feed automatically frequently have to take the spool out to re thread through the lottle holes
These things can be very sensitive with how the sting is coiled on the spool. Take your time and try to get it perfect. Look at the pre strung replacement spools for an example. also inspect the lever, usually under where the spool sits. Make sure its not to dirty and moves freely. After that when you want it to feed quickly pull and release the trigger a couple times. If you dont want it to feed the when you pull the trigger be sure to maintain how far you have it pulled back, then release it a little slower than usual. Lastly wait a few seconds before pulling again. If this doesnt work the lever may be worn out and defective. But they are super cheap and easy to replace.
2helpful
Opened hood now it won`t close
this is common it needs to be lubed, you will have to spray it good with wd40, then locate the release arm that the cable pulls to release the hood,push the arm back, have someone inside to pull the hood release lever,do this a few times and respray it until its free, here a picture of the latch, i put an arrow pointing at the lever to push back and free. hope this helps you.0429669.jpg
1helpful
2answers
Owner's manual
I found a website for you that might help. They have a lot of kenmore manuals including one similiar to your model#148.12051. The manual opened as model 1205 so maybe searching for your model as the 1201 might help too. hope this helps! =)
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/kenmore_sewing_machine_product_list.html
7helpful
2answers
My transmission will not go into park. how do i fix that
  1. Install the shift cable end of the shift cable to the transmission shift lever stud ball.
  2. Install the retainer to the shift cable and transmission bracket.
  3. Feed the shift cable through the floor panel.
  4. Lower the vehicle.
  5. Adjustment Procedure
    1. Ensure that the shift cable is not restricted.
    2. Place the shift lever into the NEUTRAL position.
    3. Position the shift cable to assume a natural routing. The shift cable must be free to move 20.0 mm (0.80 inch) axially during the adjustment under adjustment spring loads.
    4. Pull the cable end completely forward and release it. (When the cable is pulled completely forward and released, the adjustment spring will position the cable to its most rearward position.) Notice: Do not pull the shift lever ball stud forward of the transmission shift lever ball stud during installation. Pulling the shift cable end forward of the transmission shift lever ball stud before installing the shift cable end to the transmission shift lever ball stud will result in a poor adjustment.
    5. Connect the end of the shift cable to the transmission shift lever stud ball.
    6. Press the locking tab IN in order to secure the shift cable to the transmission bracket.
3helpful
2answers
4helpful
2answers
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Top Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Hand Tool Expert? Answer questions, earn points and help others
