Question about Electrical Supplies
Pro source 7500 generator. Engine runs great but produces no power. Any ideas why?
    Top Expert:
  • Electrical S... Master
  • 30,306 Answers
See you tube for reflash gen vids
Posted on Mar 10, 2019
SOURCE:
I have a pacific 7500 generator that stopped gerating electricity. Motor starts and runs great but no volts coming out
Generating section is no good. Check to see if there is an open circuit breaker in system.
Jan 01, 2016 | Electrical Supplies
My 7500 watt generator doesn't produce any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
ENGINE RUNS GREAT DOES NOT PRODUCE ANY AC CURRENT
It seems that the "generator is burn".The generator is one thing and the gen. is other.
Oct 13, 2010 | Briggs & Stratton Briggs Stratton 6200...
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Mar 06, 2010 | Electrical Supplies
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
