Left hand copper cannister - thermal cutout switch tripped (for no apparent reason) and lost second stage of heating. reset thermal cutout switch - water is now hot - but the light is not on when hot water is flowing. cutout did not trip again (Yet?) I will check the light bulb. Question: How to check for a short that is causing overheat of circuit?
SOURCE: Tankless water heater overheats
If this is not a sealed combustion unit, service the water valve OR rebuild the water valve if it is over 5 years old.
SOURCE: Not sure if my first try worked so will try again.
The easiest thing to do would be to call Bosch and just ask for a new heater for free. The other option is to call Bosch and have them send you all new elements. If there is power, there should be heat of some kind.
SOURCE: tankless electric water heater not heating
If you smell it - look fer it. It may be a bad connection on the AC supply line all the way back to the service panel or inside the heater connection panel. Bad connections cause high heat and discoloration of wires or connectors and a serious voltage drop to the appliance.
SOURCE: i have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
