Question about Measuring Tools & Sensors
How can I adjust the time on my weather station model #sgr72914?
    Top Expert:
  • 25,068 Answers
Download and read the instructions
Posted on Mar 10, 2019
Testimonial: "cannot download."
4 Suggested Answers
SOURCE:
SOURCE: How to adjust the altitude in this weather
I solved it by my self by a try and error procedure
Posted on Oct 12, 2009
  • 4 Answers
SOURCE: I can't adjust the time zone on my Sharp weather
letydullketesseduke@yahoo.com
Posted on Sep 10, 2013
lpfaff1
  • 11573 Answers
SOURCE: Smart Gear Weather Station. How can I adjust time?
George, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Mar 20, 2016
My Smart Gear STG-5939-KB, Weather Station does not indicate the correct day. Instructions say it will adjust to the date. The date is 5/4 but the dat says TUE. Any ideas?
Your Smart Gear Weather Station may be defective. I have an atomic lock that indicate DST all year round but changes time correctly. One other thought: your weather station may be set for the wrong year.
May 04, 2018 | Measuring Tools & Sensors
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Mar 20, 2016 | Measuring Tools & Sensors
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Need a manual for model cs1203 craig weather station
To change the time, press the time button. When it goes to 2000, you will see the date flashing. Adjust using up and down buttons. Then press the time button again. You can then use the up and down buttons to adjust the time. Finally, to toggle between F and C, use the up button by itself. To adjust between 24 and 12 hour clocks, press the down button.
Jun 10, 2012 | Measuring Tools & Sensors
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
Apr 05, 2012 | Measuring Tools & Sensors
How do I reset the time on my acu-rite model # 604rx
Hold the Time button until the hour blinks. When it does, use + or - to adjust. When correct, press Time again. This will cause the minute to blink - use the same buttons to adjust. When finished, press Time again.
Sep 01, 2011 | Acu-Rite Acurite Wireless Weather...
How can I get intructions to adjust the data on my RCA WERE 1001 Made in China Black oval approx 5 1/2 " high weather station?
You should be able to press and hold the 'set' button on the back of the unit, then press the + or - button, also on the back, at the same time as pressing the 'set' button. Hold for about 2 seconds and it should beep. then it is just a matter of going through each item on the station and adjusting the time, etc., with the + or - buttons.
Jun 09, 2011 | RCA WERE1000 Weather Station
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Measuring Tools & Sensors Logo
64 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
