I have an engine for my first Choo Choo and no batteries. What type is needed and is it some type of battery pack.
SOURCE: 2001 S type: starter turns but engine won't crank.
Sounds like the solenoid in the starter is not engaging fully. Is the starter making a nasty whirring sound? That could either be a fault in the starter which can be resolved with reconditioning (much cheaper than a new one) or an alternator to battery problem that is preventing enough current getting to the starter. The latter usually just allows the starter to 'click' but not turn, however with your recent problems you may wish to try and jump start the car from another vehicle and then check the votage going across your battery is at 13v to 14v. making sure the other car is no longer connected to yours first so you know what your alternator is producing. Be surprised if it isn't a problem in your starter to be honest.
SOURCE: What Type Of Battery Do I Need For A 2001 Mazda Protege
12-volt car battery -- nothing special -- any parts store can look it up for you.
SOURCE: i have a la scala tonneau women watch, the watch
The battery has its identification number on it, so if you remove the back of the watch you should be able to read the type without stopping the watch.
Or you could take it to a watch shop, who will have a stock of batteries. Removing and replacing the back of a watch sometimes takes some practice and I advise you to give the job to an expert, especially if it is a water resistant type.
SOURCE: I need an operators manual
Push the middle of the smoke stack on the engine...it makes it move forward...pushing it again stops it....again makes it go in reverse, etc, etc...turn the bell for bells sounds and smoke stack effects.
SOURCE: I need to replace my battery in my 04 V4 engine-
Goto Auto Zone they will put it in for you.
Part Number: 124R-DL
Alternate Part Number: 24F-7H-DL
Warranty: 7yr
Notes:
*** 700 cold cranking amps (875 cranking amps). *** 120 reserve minutes. -> 2 year free replacement
should be about $85.00
