Samsung Pn64d8000 64-inch 1080p 600hz 3d Plasma 8000 Series Smart Tv Logo
M Murph Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung PN64D8000. The TV will power on just fine and after some time will either shut down -power light blinks 5 times (happens most frequently), loses picture and has sound, or just loses picture and sound and does not turn off on its own. Letting the TV sit for a period of time (10-15 mins) will allow it to power on and produce picture and sound but one of the symptoms described above eventually will recur. Any idea what may be causing this? Thanks in advance
  • John Lin
    John Lin Dec 02, 2020
    I have the same issue, what was your fix?
'Victor Collazo
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Mar 10, 2019
'Victor Collazo
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
16800
Points
131
You may have bad capacitors on the power supply. Replace capacitors or buy new power supply.
5 Related Answers
Anonymous
  • 140 Answers
  • Posted on Sep 28, 2007
SOURCE: losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Sony KDF- 42WE655 Blinks 5 times No picture or sound
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
Anonymous
  • 19 Answers
  • Posted on Jun 20, 2009
SOURCE: TV works for 5 min then shuts off and power light blinks green
check your sleep mode...
Anonymous
  • 230 Answers
  • Posted on Jul 28, 2009
SOURCE: d52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
shaun taylor
  • 1527 Answers
  • Posted on Oct 25, 2009
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Power light blinks 5 times
The vertical output section should be checked for the fault. Check this site for more details.
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
1helpful
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
5answers
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
