Question about Kohler Home
I can not get my kohler one piece toilet to un plug PLEASE HELP
    Top Expert:
  • Kohler Master
  • 23,001 Answers
You have kids??? theres probably something large in the trap
Posted on Mar 10, 2019
SOURCE:
SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
phmaddnes
  • 24 Answers
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Posted on Jul 04, 2009
Digglesby
  • 71 Answers
SOURCE: Kohler one-piece has no flushing power
Don't flush more water! Trash the toilet and replace it with a toilet that uses less water and flushes efficiently; practically every manufacturer makes a dual flush or eco model. Spend your money on a good toilet rather than paying for and wasting water every day.
Posted on Nov 04, 2009
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
  • 268 Answers
SOURCE: How do we replace the seat on a Kohler K-3386-0
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Posted on Oct 07, 2010
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
Will 3" sanitary pipe be sufficient for the kohler k3427 toilet?
Yes it should be fine, go to Kohlers website and check the rough-in dimensions to see what size the waste hole is on the toilet usually 2 3/8 to 21/2. If it says 3 inch you might just need an adapter ring.
Sep 20, 2014 | Kohler - Toilet - Two-piece - Highline -...
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Try this instead:
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
I have the Kohler model 703 one piece toilet. It runs once about every ten minutes. It sounds just like a flush but nothing happens in the bowl. Any ideas?
Something is leaking. Your description sounds like tank water is slowly leaking and then the tank refills. You really need to use Kohler brand parts, as others pieces seem to not work well.
Sep 20, 2010 | Kohler Toilet - One Piece with Ingenium...
CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
May 26, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Toilet will not flush
some carpet cleaning machines have little balls that stop the water at a certain hight in the machine. could have come out and thats what is plugging the toilet
Mar 29, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
Water running off and on and comes out from top piece.
you unfortunately need a new fill valve. I say unfortunately because they are expensive, (about $120), for that model and not everywhere sells them. It it was a "regular" toilet, the part would be a any home store and cost about $10. Sorry to be the bearer of bad news. How old is the toilet? You may consider replacing the whole thing.
Aug 10, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
32 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
