SOURCE: Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
SOURCE: just set up new Sanyo DP26670. Need to switch
Hello, you'll find a download for you Sanyo tv at the following link: http://us.sanyo.com/dynamic/product/Downloads/DP26670_En-17183003.pdf. refer to page 17 for channel set up instruction.
SOURCE: TV Started to turn on
Hi
The power Supply Unit inside the TV has most likely went faulty, it's getting power but it cant convert it properly.
If its in warranty contact the manufacturer or retailer... if its out of warranty, contact your retailer and tell them "its not had a long enough life span" fingers crossed they will have good customer service and replace or repair it if it's not too old.
if not take it to a local service centre, should be a cheap repair!
...But It Is Broke :(
Good luck
Mike
