Question about Amana Dryers
How do i find out what temperature my Amana Ned 7200tw dryer uses for the various cycles?
3 Suggested Answers
SOURCE:
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: t5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 07, 2010
Testimonial: "very very good"
Fix heating on Amana ALE331RAW Electric Dryer
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 24, 2015 | Amana Dryers
HOW DO i GET THE FRONT PANEL LOOSE AT THE BOTTOM
You have to tip the unit backwards. Put a a piece of wood under it and remove the screws on the bottom of the unit. There should be one on each side.
Nov 02, 2014 | Amana Dryers
I have an Amana dryer NED4600Q0 it doesn't dry my clothes nor does it shut off can you please help me figure out a solution so I can use my dryer
GOD IS STILL GOOD !!!!
Sep 28, 2014 | Amana Dryers
Amana dryer will not heat up. What will cause that?
Sep 14, 2014 | Amana Dryers
Is the amana ned 7200tw stackable
Yes stackingkit 5303937141 to stack them
Mar 16, 2014 | Amana NED7200TW Electric Dryer
AMANA DRYER MOD # P NGD 7200TW FRONT LOAD ABOUT 1 1/2 - 2YRS OLD NOT GETTING HOT WHEN TURNED ON HOW DO I OPEN FRONT PANEL TO CHECK IGNITOR AND SENSORS
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 10, 2011 | Amana ALG230RAW Gas Dryer
T5 error code comes in my amana dryer ned 7200tw
Check for:
Mar 06, 2010 | Amana NED7200TW Electric Dryer
May 14, 2009 | Amana NED7200TW Electric Dryer
Dryers Logo
51 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
