Washing Machines Logo
Jeff Scott Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool model lCWTW4840 makes banging noise at spin cycle
Ann Masterson
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Mar 11, 2019
Ann Masterson
Expert
Level 2:
New Friend:
Answers
152
Questions
Helped
46845
Points
227
Sounds like bearings or have you put 1 big item on its own and it unbalanced
Jim Chinnery
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Mar 10, 2019
Jim Chinnery
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
Helped
4072
Points
21
Open the door, put your hand in and onto the top of the inner drum. Push upwards, if it moves upwards for more than a few millimeters it is probably the bearings worn.
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Mar 04, 2008
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Anonymous
  • 373 Answers
  • Posted on Dec 14, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
adrian halligan
  • 1075 Answers
  • Posted on Feb 15, 2009
SOURCE: banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Anonymous
  • 100 Answers
  • Posted on Mar 29, 2009
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Anonymous
  • Posted on May 15, 2009
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
2helpful
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
1helpful
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
4helpful
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
