Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Amazon.com, Inc.
Rating: 3.8 - 30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
hi , you panasonic plasma tv maybe have more than one problems in the sub power supply # etx2mm704mgb & power supply unit # etx2mm704mgh or #etx2mm704mgn. you must check original one what # ? parts you buy on shop jimmy.com. good luck!
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
