Question about Electrical Supplies
Is there a fuse inside of charger? - Electrical Supplies
    Top Expert:
  • 64,241 Answers
NOT A CLUE HERE
Posted on Mar 10, 2019
SOURCE:
I own 2006 toyota sienna van, one cigarate charger doen't work which fuse shoud i need to check
Check the fuse marked "power outlet" on the fuse panel inside lower left of the dash, there may be more than one marked like this.
Feb 16, 2012 | 2006 Toyota Sienna
Charger not working
3 possible reasons:
1. Usually the cable of the charger is cut inside (the wire inside the cable).
Try to change just the cable.
2. The battery is Dead so it cannot be charged. Change battery.
3. Inside the charger, the fuse or transformer are dead. Change them one by one and test in the middle.
Another brilliant solution is: Buy a cheap Charger that fits your voltage and change the plug so as to bit your tool.
Jul 21, 2011 | McCulloch Drills
Power socket in middle counsole wont charge my cell phone
Check the fuse for the socket and check to see if the charger works in a different vehicle. The chargers will also have a fuse inside them that can go bad. If the fuse isn't burnt out for the socket and the charger doesn't work in another car than its probably the fuse in the charger.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 24, 2010 | 2006 Kia Optima
No output from charger model SF-1252MA
the transformers of these chargers have whats called a thermal fuse....usually this fuse is wired inside the transformer itself....it is designed so that in case of excessive overloads or high temperature, the fuse will blow...this is to protect your home wiring from overheating and possibly catching fire.......it is a safety feature....by touching the cables together even for a moment caused an extreme overload condition which probably took the fuse out....you can still fix it but you need to open a few layers of the transformers wrapping to get access to the fuse.....some systems have other components called NTC's or PTC's....these are also temperature safety components.....chances of the regulating components going bad ae slim because their capacities are designed for high power, high temp conditions so chances are that only the fuse is gone....good luck
Apr 09, 2010 | Schumacher & Fast Charge Starter Charger
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Nov 05, 2009 | 2001 Ford Focus
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
I have a ryobi impact drill and battery charger that has stopped
yes, most chargers have internal fusses.
Oct 23, 2009 | Drills
The light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
May 20, 2009 | Black & Decker Black And Decker 12 Volt...
Car charger
ther is a fuse for the lighter unit ther are fuses in under the bonnet and in the inside have you checked them all
May 17, 2009 | 2004 Honda Accord
Car charger fuse
The fuse is just inside the tip that plugs in the car lighter. You screw it off and out comes the fuse. As for the fuse you can go to any local electronics store with the fuse that you get out of the charger and ask if they have it.
Feb 05, 2009 | Garmin StreetPilot c340 GPS Receiver
Electrical Supplies Logo
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
