SOURCE: Dad has a jazzy select
VB the batteries are too weak for the chargers to pick up. Unfortunately you will have to puchase new batteries. Now since the facility was responsible for not keeping the batteries charged I would ask that they pay for the new ones. Good luck with that. The batteries you need are U1 batteries. If you have a battery warehouse type store near you they should have the batteries or an Interstate Battery outlet store. The batteries should be around $200.00 for two. Try not to get them at a local provider cause they'll charge you more. Hopes this Helps you
SOURCE: Our Jazzy Select G.T. power
Hi LOCKING/UNLOCKING THE VSI The VSI has a feature that enables you to lock your power chair to prevent unauthorized use. To lock the VSI: 1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep. 2. Release the on/off key. 3. Push the joystick to the full forward position until the VSI beeps. 4. Pull the joystick to the full rearward position until the VSI beeps. 5. Release the joystick. There should be a long beep. 6. The VSI is now locked. To unlock the VSI: 1. Press the on/off key and power on the VSI. The maximum speed/profile
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
indicator should ripple side to side.
Good Luck
mi mobility
SOURCE: My Pride Jazzy Jet 2
Are you comfortable working on the electronic cable / connector?
Check the temperature charger's by hand. It should be warm to the touch when power on.
Since you has the unit plug in for days,it should be warm to the touch.
You will need to has a volt meter to check the voltage output on PIN 1 and 2.
Remove the power cord from the outlet.
Inspect the 3 small pins on the XLR (ROUND connector) to the scooter.
Make sure the 3 pins are not damage.
Open the metal 3 pins connector by sliding it back on the cord.
Check for loose connection on the solder tabs.
There should be total of 3 solid solder connections these tabs.
Close up the connector.
Check the connect on the scooter end.
The 3 pins must be clean and able to make the connection.
Please post more information and result on reply.
SOURCE: battery charger light doesnt work showing that the batteries are being charged.
okay first of all check that the batteries can be seen from the charger socket, otherwords get a electronic meter and insert the probes in the two outside holes , do you get a reading on DC ?
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
