Question about Korg Music
My Korg C-320 LC won’t turn on. The power button is not turning on. This happened quite suddenly....worked one day, would not turn on the next. Help!!
    Problem Solver:
  • 18 Answers
This is the help that the owner manual offers...completely useless.
My Korg C-320 LC won’t turn on.  The power button  - screen shot 2019-03-26 at 18.14.12-qgyx2ovz4joj5a5xoqk2ua2x-5-0.pngHowever, it is likely that if your piano isn't turning on, either your connection is bust or your AC power adapter is broken. You can purchase a replacement relatively cheaply. https://www.thomann.de/gb/korg_netzteil_ka_320.htm
Posted on Mar 26, 2019
SOURCE:
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
SOURCE: F35750ST watching one day, turned off, will not come on the next day.
my tv turns off andon
Posted on Jun 23, 2008
proton77
  • 1183 Answers
SOURCE: Will not turn on
You can try the following steps:
1. Disconnect all the cables from the monitor
2. Wait for 5 minutes and press the power button in the front once ( donnot connect the cables at this step)
3. Reconnect the power cable only to the monitor
4. Power on the monitor and check if you see a self test running on the screen
If the selftest feature is not running the monitor has gone bad. All dell monitor if purchased on a seprate order ,hold a 3 yr replacement warranty. If you have got the same with your dell computer, call Dell to check if its under warranty.
Thanks
proton
Posted on Nov 01, 2008
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 225 Answers
SOURCE: Sylvania LC 320 SLX -
I recently repaired this exact TV that had a similar problem. First take the back cover off and check all the electrolitic capacitors on all the boards to see if they are bulging or leaking (if so replace them). If they all look good you can unplug everything from the Inverter board. The inverter board has the pink and white wire plugs going into it. Then try to power on the TV and if the green light comes on, and stays on, then you know the problem is in the inverter board. My problem was in the inverter and I found Q1500 (N Channel MOSFET) shorted Gate, Drain, and Source together. You can check that with an ohm meter. Just for safe measure I also replaced Q1550 and it is the same exact part as Q1500. Here's the link to the part so you can order it:
http://www.newark.com/stmicroelectronics/stp17nk40zfp/mosfet-n-to-220fp/dp/26M3680
Posted on May 15, 2011
Testimonial: "Thanks for the tip, L-switch! I'll check the caps and inverter board and go from there. have a great day."
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My alesis m1 active 320 usb speakers will not turn off even when i turn the knob ALL they way off.
I have the same problem. ¿What happened when the problem started? I disconnected them and left them thus for a day or so. When I tried again, the problem happened. Did you find a solution yet?
Apr 28, 2014 | Alesis M1 Active 320 USB Speakers
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
After having been in safe waterproof storage during cyclone season I,ve unwrapped my korg pa 500 and plugged it in but it doesn,t boot up .The sreen is lit well with simply "Korg"...
First thing... make sure you are using the KA320 power adapter with it. We will work from there.
The unit probably is sensing an error of some type. Check these things: That NO key or button is STUCK down. Next, one could try reseating the memory sticks if you have expanded memory.
Let me know if you find a button or key is stuck down (not uncommon when unit has been wrapped) or you are using the wrong power adapter.
Jun 10, 2011 | Korg PA500 Professional Arranger 61 Key...
My korg kp3 has worked perfectly for the last three years. The other day when I plugged it in and engaged the power switch, it would not turn on. I haven't dropped the unit or the power supply and...
I agree, it's probably either the power supply (has it a fuse?) or the power connector or the power switch or an internal fuse. Probably a simple fix.
Oct 31, 2017 | Korg KP3 KAOSS Pad DJ Effects
Our brand new Korg SP170 worked great for several days. Today all the C keys and all the E keys quit making any sound. We checked all cords and connections, turned it off a bit and back on, with it plugged...
There probably is a cable or connection inside that is loose... The keys are scanned as a matrix so some connections are in common...
HOWEVER: Since you have had it several days DO NOT delay, call for warranty service. This is not a DIY repair unless you are adept and comfortable with electronics.
Dec 10, 2010 | Korg SP170BK 88-key Digital Slab Piano...
My korg le won't turn on.. it worked great then one day went to turn it on and nothing any suggestions?
First thing is to check your power adapter. It should be producing something over 9 volts AC. Also check that this connector is seated.
Also check the adapter is getting power. Some have had their adapter in a plug strip and the weight of the adapter has turned off the switch on the strip... silly but it happens.
Nov 11, 2009 | Music
Music Logo
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
