SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
SOURCE: I have a 3yr old
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Testimonial: "freewheel lever! thank you very much"
