SOURCE: recover deleted recording from digital recorder - Olympus VN 4100
sadly NO. Once it's gone it's gone.
SOURCE: How do I recover a recording deleted accidentally from Sansa e250
It is possible to recover your lost recordings.
First things first: DO NOT take any more recordings with the MP3 that you want to recover records from in case you may quite possibly ruin your chances of recovery.
Then Connect the MP3 to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your recordings with Wondershare Recovery Software from the following link:
Video Audio Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Do NOT try & write anything back to your MP3 until you can recover your recordings safely!
SOURCE: Need to recover deleted file from recorder
Sorry for a late reply but chances are high to recover your deleted files.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
