SOURCE: I don't know how to use a Bernina foot I have
There are videos on the Bernina website on how to use the feet. #61 -#69 are all hemming feet. Look on this page of presser feet videos. Click the one that says #64.
http://www.berninausa.com/content-n401-sUS.html
hope this helps.
Rick
SOURCE: loose pressure foot - how do I tighten on a Bernina 160 Virtuosa?
use small screwdriver provided, usually orange, streight edge,
SOURCE: I turned off my machine to change the pressure
The machine Knows the foot number buy the small glass part of the foot just on the upper right side of the foot. Check to see if that is not damaged and clean. Also check the sensor on the machine just above the foot for not damage and clean. If that is good make sure your foot is paralel with the stitch plate. Do this buy putting a single hole foot on your machine and make sure the needle is right in the center. If this does not work you will need to take it in. May be a bad sensor or unpulged but that is rare.
Also not all bernina feed have this foot sensor, if this is the case it will not read it
hope this helps
SOURCE: got bernina 1015 sport sewing
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Testimonial: "very helpful thanks"
try
ebay
sewingpartsonline.com
sew4less.com
or try these sites --you may have to email them about the part
sewvacdoctor.com
a1sewingmachines.com
