Medical Logo
Cristil Baldwin Posted on Mar 08, 2019
Have Schiller AT-2 Plus Combo ECG and Spirometer. Unable to print results of spirometry tests. I can see results on screen but when I press print nothing happens. What to do?
tech6789
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Apr 04, 2019
tech6789
Contributor
Level 1:
New Friend:
Answers
11
Questions
Helped
2837
Points
23
Generically, look for report formating settings / configuration options to see which parts/ kinds of data are included/ enabled for printouts
tech6789
1 Related Answer
Anonymous
  • 16 Answers
  • Posted on Jul 22, 2009
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
1helpful
I HAVE A SCHILLER ATP-2 PLUS EKG SYSTEM. ITS PLUGGED INTO WALL. IT BEGINS TO PRINT AND SHUTS OFF. I TRY TO SAVE IT BUT WHEN I DO "ALT" "S" IT SAYS "NO DATA".
The battery is faulty. You have to replace the battery.
If you wish to get some details about Schiller ECG machine repair then check the following link.
http://electro-medical.blogspot.com/
How do I change date on machine
I just get on my iPhone machine and text her that I can't meet tonight and that we will have to get together another time.
2helpful
AT2+ doesn't print
HI,
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Battery
Ajin
Every time that i press auto print the scchiller at-2 plus turns off all the time
hi,
Change the battery, will solve your problem. Its a 12v battery. For replacing the battery you have to open the ecg machine by removing the screws at its bottom.
ok
2answers
My schiller at 102 is not charging and shuts off every time i attempt to print. Any ideas on what might be the problem?
hi,
One of the cause for this problem is the faulty backup battery. normally ecg machines runs on battery even if the power is connected. The power supply of ecg machines is meant for charging purpose only and doesn't have that much power to run the machine. also the companies will not recommend to take ecg at mines on condition.
First of all check the charging voltage is there or not. The battery charging voltage is 13.8v . check is the voltage is there at the pins of battery ,in mains on condition. If its ok the the battery have to be replaced. Normally the battery will be faulty.
ok
5helpful
Cannot change the time and date on my AT-2 Plus
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
3helpful
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
I have Schiller AT-2 Plus, i need instruction manual,or guide me how to chnage date and time,hospital name.
i want to configure my Schiller at-2 plus ecg machine from dutch to english and 3channel to 6channel
4helpful
2answers
The schiller at 2 plus ecg machine not printing ecg
Top Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
