SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
SOURCE: How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
SOURCE: MISSING INSTRUCTION MANUAL
C'mon! http://www.dewalt.com/us/service/instruction_manuals.asp?SKU=dw70&submit=Submit
