Question about Janome Sewing Machines
Janome HD 3000 - Bobbin casing keeps popping up - stopping/jamming the sewing. What to do to fix this?
Bobbin casing popping up at the front
    Habit-Forming:
  • 21 Answers
Have you cleaned the bobbin holder recently? If not, that could be the problem. See here: https://www.janome.com/siteassets/support/manuals/economy-models/inst-book-hd-3000eng.pdf
(page 47)
Posted on Mar 14, 2019
SOURCE:
bargainbox
  • 1388 Answers
SOURCE: bobbin jams
Have a look at this solution to tension troubles
http://www.fixya.com/support/t360510-machine_stitch_complete_stitch
Bargain Box
Posted on Jan 27, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
Not sewing stich
Don't know the make/model of your machine...
The bobbin case has a latch that you need to hold open until it is in position. When you let go of the latch, it should be secure.
Inserting the Janome Front Loading Bobbin Case
Here's a manual for your machine:
http://www.singerco.com/support/instruction-manuals/search
http://www.getcrafty.com/forum/share-craft/8131-help-big-problem-singer-7033-sewing-machine.html
https://www.reddit.com/r/sewhelp/comments/1kcovm/singer_7033_bobbin_thread_wont_stitch/
Apr 07, 2016 | Sewing Machines
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
Janome sewist 525s my bobbin shuttle keeps popping out
try another bobbin, that one might be warped
use a can of computer air in the bobbin area for lint
if the problem persists then the machine should be checked
Mar 29, 2014 | Janome Sewist 525S Mechanical Sewing...
Janome bobbin problems
try getting a new bobbin case
Mar 23, 2014 | Sewing Machines
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
My Janome 6500p is having bobbin issues
here are my suggestions
1. when your sewing check to see if the thread is coming off the thead take up lever,, I've had this to happen to me & it can jam a sewing machine up
2. it's possible that the bobbin case is worn & needs to be replaced
3.also check your top tension
4. try rethreading the machine top thread & bobbin
Feb 06, 2012 | Janome Sewing Machines
Janome 6500 jamming - cleaned out bobbin case - no help
Have you removed the bobbin holder and then put it back in lining up the little red markings on the right hand side? If the case has moved slightly then it will keep jamming and the bobbin thread won't clear to form a stitch. The case is held in place by a magnet and a stopper but it will dislodge if you have a bad thread jam, then it keeps happening even if you have removed all the thread because its not in position.
Check this solution for image how to remove and replace the bobbin case. http://www.fixya.com/support/t9289728-bobbin_seems
When you take out the bobbin case, carefully inspect it for any damage and burrs in the black plastic, if there are any then file them carefully out with a nail file or fine sandpaper, a burr will keep catching thread too. Or you may actually need to replace the bobbin holder if it has been pierced by the needle badly, they are about $35 or so.
You may also want to get it serviced. On my 6500 during its last service the technician added a little piece that is a Janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which is holding the bobbin holder in place better. Haven't had a major jam up since this was fitted so you may want to get this fitted on yours too.
Jul 19, 2011 | Janome Memorycraft 6500P Computerized...
Sewing Machines Logo
49 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
