SOURCE: The water going into the tray
Hi There The answer is very simple it is the main seal from the from the press unit which can be changed if you are not handicapped with mechanical things. The O-ring is a red color on with a shore of 50+-5% and for a heat application of around 100 degree Celsius. The dimensions are 38mm ID by 3.55mm diameter. I hope this info was helpful if not u can call 00971506544928 or just e-mail to [email protected] and I will guide u through.
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
SOURCE: Rubber seals for wand sections
Try eBay or you're local plumbing/bathroom store. What you need are called o-rings.
My problem was that there's an o-ring on a spike in the hose attachment and that was split which meant it leaked water/steam. I replaced it and it's working fine again. I got my o-ring (in a pack of 200 assorted sizes) from eBay for about £3 but that was only because I was too lazy to go down to my local plumbing/bathroom shop which probably would have sold me 1 for a few pence. Much better than £50 to replace the hose!
