Question about Janome Sewing Machines
Janome ms3015 trouble with stitch selector. I have to turn the knob back and forth several times before the stitch selected will release. I’ve set stitch width to zero, turned hand wheel, etc. used frequently so it’s not an idle issue. I’ve inspected the stitch selection area. There is a white substance that appears to be the grease or lubricant of some sort. I don’t want to break it as turning the stitch selector knob several times just to change stitches seems excessive and I’m hoping someone can shed some light on this problem for me.
SOURCE:
mohammed387
  • 1952 Answers
SOURCE: cannot not see the stitch selected on screen
Look in your manual to find out where on your machine the dimmer is.
Posted on Feb 12, 2009
  • 1116 Answers
SOURCE: my stitch selector keeps turning around and around
You will need to take the machine in for service.
Posted on Feb 27, 2010
SOURCE: Viking Husqvarna Model 6020 stitch selector will not turn.
what causes a machine to sew only tiny stitches and the adjustment length knob to be set on all selections including 1,2,3,or 4 and still only have the tiny stitch sew out. This is a Viking 6020 machine problem
Posted on May 08, 2011
  • 1456 Answers
SOURCE: I have a Viking 6370 sewing machine. I can not
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Posted on Jul 12, 2011
Testimonial: "That was the problem exactly. I am going to order a new cam gear and replace it. Thanks"
SOURCE: stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
Posted on Nov 16, 2012
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Apr 23, 2010 | Husqvarna Viking 1
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Need help with automatic buttonhole for my Janome 6019. How do I use it?
Right, now I've figured this out :)
Put your button in the holder on the foot - fiddle about with it enough and I'm sure you'll work out how, one bit slides open and then you can close it again to hold the button.
Then fit the foot to the machine - the piece with the button in goes at the back.
Select 2 on the stitch selector, 4.5 on the stitch width and buttonhole on the stitch length.
Using scraps make up a piece of fabric with the same number and construction of layers as your finished garment and do a practice run or three.
You can set the actual feed length using the -.+ control (beside the feed release switch at the front, below the sewing table).
Between button holes you need to reset by turning the stitch selector wheel slightly until you hear a click.
Once you're happy with the method, think you have the settings as you want them and feel you have done enough practice try it for real on the garment.
Note: the button holes come out a bit long - just don't cut down the whole length or you may need to hand sew them tighter.
Mar 03, 2009 | Janome 6019QC Mechanical Sewing Machine
Cannot not see the stitch selected on screen
Feb 12, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
