Check
the display for an error message. If the display reads "Clearing paper
from printer," the engine has detected a jam and is attempting to eject
the jammed pages automatically. These pages will often be blank.
Check
the display for "Performing PRINT/STOP TEST" or "Performing SERVICE
TEST." Either of these messages indicates that the printer is going
through a test procedure that may eject blank pages.
Reduce
the amount of paper in the input tray if the printer is feeding
multiple blank sheets at a time. The printer will pull extra pages
through if the input tray is overfilled.
Replace
the paper in the input tray with the correct size if needed. If the
4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
Replace
the ink cartridges if certain colors are blank on the page. Replace the
black cartridge if printing a black text document that is coming out
blank. The printer may attempt to print even if the ink level is low or
empty, but will unable to print anything on the page, causing it to
come out blank.
Remove
the sealing tape from newly installed cartridges. The tape covers the
print heads and should be removed before installing the cartridges. If
the tape is left on, it will prevent ink from getting on the pages as
they print.
Press
the "Check mark" button on the control panel to enter the printer menu.
Run a diagnostic so the printer can attempt to determine the cause of
the blank pages printing. Press the up or down arrow to select
"Diagnostics." Press the "Check mark" button. Press the "Down" arrow to
highlight "PQ Troubleshooting." Press the "Check mark" button. The
printer runs a diagnostic and returns to a ready state when done.
Check whether the "print preview" on the screen shows blank too... Make sure the document you are printing doesn't have blank pages. You may think that it might be one page, it might be two. Somehow you may have inserted a blank page or two. Running a printer operation check If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer. get more information and help from here........ http://www.fixya.com/support/t5860328-hp_laserjet_1320_printer_printing_blank
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
its the documentation for your printer and you will see there what are the factors a laser printer prints a blank paper and the things you will need to do. Just reply if you are unable to find it there. Hope it helps.
