Hello Lemissa, if you try to change to playback mode, on the computer or with your remote control and you do not succeed, it could be that your Panasonic SA VKX60 has a problem in the circuit of functions
Usually this fault is generated by the keys that are under each key or button that you press on your computer
I suggest you, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Lemissa, si intentas cambiar a modo reproduccion, en el equipo o con su control remoto y no lo logras, puede ser que tu Panasonic SA VKX60 tenga un problema en el circuito de funciones
Por lo general esta falla la generan las llaves que estan debajo de cada tecla o boton que presionas en tu equipo
Te sugiero, busques un servicio tecnico especializado
Espero que puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/panasonic_sa-vk90.pdf/download.html
SOURCE: Panasonic home theatre SA-PT850, I
this link will help....
http://www.dvdcodes.net/prods/panasonic/pan40-49.php
SOURCE: my panasonic sa ht7o plays dvds fine but no
you have it hooked up as a component with one of the three video cables crossed
SOURCE: can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
SOURCE: what is power ic number of my Pana sonic SA-VKX60
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=panasonic+SA-PT750
See "Play Mode" on Page 17
