SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
SOURCE: brinks safe
OKAY! THIS IS WHAT MY INSTRUCTIONS TELL ME, HOPE THAT THIS HELPS! HERE YOU GO - TURN THE DIAL TO THE RIGHT PASSING THE 1st NUMBER 4 TIMES & STOPPING ON THE 1ST NUMBER THE NEXT TIME AROUND / TURN THE DIAL TO THE LEFT PASSING THE 2nd NUMBER 2 TIMES & STOPPING AR THAT NUMBER THE NEXT TIME SROUND / TURN THE DIAL TO THE RIGHT PASSING THE 3rd NUMBER THE NEXT TIME AROUND / TURN THE DIAL TO THE LEFT TO THE 4th NUMBER & STOP - NOW INSERT THE KEY IN THE CYLINDRICAL LOCK & TURN IT THE THE RIGHT TO OPEN.
SOURCE: need to reset combination on brinks digital home safe model 5040
the Brinks Company has a phone number you can call to get instructions on sending them a letter for a combination. It is 1-800-832-5834
SOURCE: LOST COMBINATION - BRINKS SAFE 5054
You can mail a notorized letter, requesting a combination...include model and serial number...mail to Sisco, 2835 E, Ana Street, Compton, CA 90221.....or fax it to 310-638-3489. I had the same problem and found out thru a Brinks website.
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
