SOURCE: Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
SOURCE: Motorazr V3 Status indicator no longers displays envelope for voice messages
Why am I receiving a memory full notification?
Memory full warning notifications are shown once the SMS memory reaches 80% full, which is 80 out of 100 SMS.
The notifications show up every time on receiving a new message. On reaching 100%, "Memory full notification" message is shown and no new messages will be received until we make space for incoming messages by deleting some from the inbox.
Memory full warning notices are shown only if "Auto Erase Inbox" is set to Off in Messaging settings (Menu -> Settings -> Messaging).
If set to On, then these notices are not shown. By default this is set to Off.
SOURCE: remove hearing impaired text from screen
If you are using a cable box, then the closed captioning is turned on & off with the cable box, not with the TV remote.
SOURCE: Toshiba DK3210SD DADM3220 Set Default Volume Control High for Hearing Imparied Individual
this must be done through system programming and will require a technician to program this through winadmin, unless you have access to winadmin
