Ovens Logo
M
Mark Whisenant Posted on Mar 08, 2019
LG LRE30757ST Bake and Broil relays getting extremely hot during warm up and smoking. Relay control board has been replaced due to oven not heating, what else am I missing?
pkaiser74288
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 37 Answers
  • Posted on Apr 16, 2019
pkaiser74288
Contributor
Level 1:
Cheetah:
Night Owl:
Answers
37
Questions
Helped
20326
Points
40
Check the spade terminals on the relays and make sure they are not loose/sloppy.
1 Related Answer
Anonymous
  • 2605 Answers
  • Posted on Apr 02, 2010
SOURCE: bake and broil top oven not functioning with system
While the control board could be faulty, it is certainly not what I`d suspect initially. Do these symptom`s follow a self clean cycle of the upper oven ? Is your oven actually a SC302 double wall oven as the post header implies ?
I ask because the symptoms you describe are a common occurrence when the hi-limit has tripped. The display will indicate the oven is indeed "on" but it will not heat do to the circuit being interrupted by the hi-limit ( which is what it was designed to do ).
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down.
Let me know if I can assist you further. If this solves your problem please rate the solution accordingly, if not let me know and I`ll try to guide you through other possible scenario`s.
Thanks for visiting "fixya" and good luck.
macmarkus :)
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
May 20, 2015 • Ovens
Why is ignition still working after oven is lit
Oven Control Board
Relay board:
May 10, 2015 • Ovens
1helpful
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 • Ovens
Fisher Paykel double oven light and heat won't shut off
Oven Control Board
Relay board:
Element heats up when we only put oven light on
Oven Control Board
Relay board:
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
2answers
Oven will not shut off just keeps getting hotter
Oven Control Board
Relay board:
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Oven Control Board
Relay board:
1helpful
The oven will not completely heat
Try a few drops of vegetable oil on the lower pan of the oven, and turn it on. If you do not get smoke during pre-heat, chances are your lower element is not working properly. If you DO get copious amounts of smoke off the pan, the problem could be with the temperature sensor.
If your lower element is not functioning, and if your broil function works just fine, the problem may be isolated to the relay control board. (relay K4 controls half of the 240V required to run the Bake element correctly)
Upper oven bake coil stays on.
Stove will not turn offCHECK
Oven Control Board
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately.ALSO CHECK THE BAKE AND BROIL ELEMENT.
Top LG Ovens Experts
vince
Paul Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
