SOURCE: SINGER CURVY: It jammed while sewing felt. Taking
the thread keeps gathering in big bunches under the material~i adjusted the tension but still gathers~Im wondering if there is something stuck wonder the plate~THanks
SOURCE: singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
SOURCE: The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
SOURCE: I have Singer Curvy 8763.
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
SOURCE: Disengaging mechanisam for bobbin winding Foot pedal not sensative enought
Foot pedal carbon brushes may be worn and need to be replaced.
