SOURCE: Persistent paper jam message
In response to a question by Fixya. I solved it by searching throgh all references to paper jams on Fixya. I found a solution which I have already described. This is a very helpful site.
SOURCE: styrofoam inside of my Haier HWF05XC7
It should remain there it is the insulation seperating the condensing side from the evaporating side you may nve to reach in and move it around to prevent the destruction of the foam.
SOURCE: Lexmark X5100 printer. I copied
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
SOURCE: Little Tikes Playhouse DISassembly help needed
Use a rubber mallet and be careful. You can put holes in the plastic.
If this is the yellow house with a pink door and blue roof, the corner shelf will take some elbow grease. It is a little difficult to get it out.
Keep tryin though.
SOURCE: I need to disassemble a Lexmark 2600 (all in one)
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
