I tried cleaning the corona wires and cleaning the drum rollers and still getting the two bands. Any other ideas?
SOURCE: Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
SOURCE: Corona wire problems
Read the following links:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_021.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: print problems with brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
SOURCE: poor print quality from Brother MFC-8860DN
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !!
On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy
scan window OR the laser scan window can get dirty. If the fax scan
window is dirty, you see streaks on outgoing faxes and copies (but NOT
incoming faxes). If the laser scan window is dirty, you see streaks on
all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
