Cindy OBradovic Posted on Mar 07, 2019
FFCM1155US manual clock set instructions do not work. Pressed Clock button. Pressed in time. Pressed START. When I press start the display goes black. Tried pressing clock button again but time doesn’t advance. Tried calling Frigidaire yesterday evening and this morning. Recording tells me to call back later. Help!
Lawrence Barbee
Level 1:
Habit-Forming:
New Friend:
  • Contributor 25 Answers
  • Posted on Mar 07, 2019
Lawrence Barbee
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
25
Questions
Helped
4926
Points
82
Is your oven in power save mode? Does oP-4 scroll across the display? The power save mode turns off the time of day clock display according to page 17 of the user manual. If power save is turned on to turn it off press the clock/options 4 times (if op-4 appears in the display then press clock/options 4 more times to turn off power save mode. Then you should be able to set the time of day clock by pressing clock/options ONCE enter the time and press start. Hope this helps.
5 Related Answers
A
Anonymous
  • Posted on Mar 27, 2007
SOURCE: How do I set the (time set) clock?
Hold down the TimeSet/Repeat button. it will say the day. Release that button and hold down the On/OFF button to set the day. Repeat the same procedure and it will set the Hour. Repeat it again to set the Minutes
A
Anonymous
  • Posted on Nov 09, 2007
SOURCE: needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Anonymous
  • Posted on Feb 17, 2008
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Anonymous
  • Posted on Aug 26, 2008
SOURCE: Clock working, but not displaying time
They say to hold the button for 14 seconds or til it beeps, for it to stay on.
Anonymous
  • 3 Answers
  • Posted on Dec 28, 2008
SOURCE: Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
1helpful
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
How do I change the clock on a oxo digital timer?
I'm assuming that you're referring to OXO's Digital Timer Model #1061978. OXO doesn't provide a copy of the instruction booklet for download, but I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
2helpful
2answers
I have lost the instructions on how to set the time and date for a digital multi clock GH120A, please tell me how
https://m.blog.naver.com/PostView.nhn?blogId=mobile_app_top&logNo=220570562627&proxyReferer=https://translate.googleusercontent.com/translate_p?hl=en&prev=search&sl=ko&u=http://m.blog.naver.com/mobile_app_top/220570562627&depth=1&rurl=translate.google.com&sp=nmt4&xid=25657,15700022,15700186,15700191,15700256,15700259&usg=ALkJrhgAAAAAXRePT_E1IEH3FJYm7TS9LAEefyLAgoL5
Visual Think December 16, 2013 23:09
Add neighbors Body Other Functions
For the GH120A / GH-120A,
Multi stopwatch / table clock / stopwatch / stopwatch timer, etc.,
Just have an alarm function, a small digital watch with a stopwatch function.
This watch,
I think there are so many users that I can often see at someone's house, and I think it will be difficult to find the manual later.
sometimes,
I do not think it's inconvenient for someone to read this manual.
Below is the manual.
1. Button Description
- MODE : Each time the button is pressed, the sequence changes as follows.
; Current time ? stopwatch ? alarm setting ? time / day / calendar setting ? current time
- RESET : When the stopwatch function is activated
; STOPWATCH STOP - RESET STOPPER TO 00:00
; When the stopwatch is started - On the screen, the first stop is displayed one second, and the second stopwatch is running internally.
(It can be useful when measuring 1st and 2nd records when running 100m)
At this time, press the START / STOP button and press the RESET button again to display the last second
- START / STOP
; When the stopwatch function is activated - Start or stop the stopwatch function
; Time display function - Date display
; When setting alarm or time - Function to adjust set value (time / minute increase, date increase, etc.)
- Back button
; Press once to activate the backlight for 3 seconds (keep lighting while pressing)
- Back round switch
; When the switch is turned off, the alarm sound and the button sound are turned ON (ON character display state is ON)
; When the switch is raised, the alarm sound and the button sound are turned off (OFF character is OFF)
2. Feature Description
- current time / date / day setting
; Press MODE button 3 times in time display mode
? If you press START button,
? Pressing the RESET button (minute blinking), pressing the START button increases the minute
? Pressing the RESET button (time flickering, pressing the START button increases the time,
Change AM / PM after 12 hours
? Press RESET button (date blinking), START button
? Pressing the RESET button (blinking the month), START button
? Pressing the RESET button (blinking day), START button
? Press the MODE button to complete the setting.
- Stopwatch (stopwatch)
; Changed to the stopwatch function with the MODE button pressed once (0:00:00) in the time display mode.
? Press the START / STOP button to turn the stopwatch on and off
(However, if the RESET button is pressed during the stopwatch operation, the stopwatch stops, but internally,
The second clock is still running, press the START / STOP button once,
When the RESET button is pressed, the second stopwatch is stopped)
- Alarm function
; Press the MODE button twice in the time display mode (the flashing hour part appears on the screen)
? Timed by START / STOP button
? Pressing the RESET button (blinks for a minute)
? Split by START / STOP button
? Press the MODE button to enter the time display mode (create a bell shape on the screen)
; Disable / set alarm function
If the RESET button and the START / STOP button are touched simultaneously, the bell disappears and the alarm is canceled.
(Press again the RESET button and START / STOP button again to display the bell shape and activate the alarm function)
- SNOOZE
; When the alarm sounds, pressing the RESET button completely turns off the alarm,
; When you press the START / STOP button (bell blinks)
; After the alarm is turned off for a while, the alarm sounds every 4 to 5 minutes.
; To turn off the alarm completely, press the RESET button.
- Hourly time signal notification
; It is a function that sounds once every hour,
; While in the time display mode, press the MODE button while holding down the RESET button.
; When pressed,
; If all the day of the week display is visible on the screen, the time notification function is ON,
; OFF state if no day of the week is displayed on the screen
- Backlight function
; Press the round button on the back once to activate the gauge for about 3 seconds (press and hold to continue)
- 12/24 time system change
; Press MODE button 3 times (second blinking)
? Press the RESET button twice (at the time)
? Press the START / STOP button once to alternately display AM / PM / 24 hour display with increasing time
? Press the MODE button after setting is completed.
This concludes the GH120A User Manual (manual) posting.
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
1helpful
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
54helpful
9answers
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 • Ovens
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
